Group: DynoMotion Message: 7471 From: tmday7 Date: 5/15/2013
Subject: Neg Limit Disabled Axis
I just installed my KFLOP interface board, which i also did some re routing of bits and need some help with the C Programs.
After i start Mach3 and click Reset, I get "X Axis Disabled" in status area.
Kmotion Console window says .....
Neg Limit Disabled Axis :0
Neg Limit Disabled Axis :1
Simulated Manual Mode off
Pulse Estop
The above prints every time i run my init C program.
In the Axis window of Kmotion, i can not Enable axes 0 or 1.
Bits i have changed or rerouted from my previous working setup are...
Manual Mode Switch-IO45 to IO25
X Limit Switch- IO6 to IO16
Y Limit Switch-IO7 to IO17
Z Limit Switch- IO15 to IO18
ESTOP Switch -IO14 to IO23
Here is link to C programs before interface board....
http://tech.groups.yahoo.com/group/DynoMotion/files/KFLOP%20MillDrill/C%20Programs/Before%20Interface/
Here is link to C programs that i have altered to match new bits....
http://tech.groups.yahoo.com/group/DynoMotion/files/KFLOP%20MillDrill/C%20Programs/After%20Interface/
Any help always appreciated,
Troy
Group: DynoMotion Message: 7474 From: tmday7 Date: 5/16/2013
Subject: Re: Neg Limit Disabled Axis
Made a little progress.
In my init C program Mach3_CL_PMDX-125(Version5,1).c, i changed this...
// enable/disable limits based on a
// DRO downloaded from Mach3
if (*pin == 0)<----This is what i changed.
ch0->LimitSwitchOptions = 0x0606000f;
ch1->LimitSwitchOptions = 0x0707000f;
ch2->LimitSwitchOptions = 0x0f0f000f;
to this...
if (*pin == 1)<-----This is what i changed.
Now a new issue when referencing axis X and Y. What happens is axis moves till limit switch is triggered then moves out of switch and zeroes axis. After zero i get Axis Disabled fault in Mach3, which ever axis iam referencing at the time.
This happens right after the C program changes Limit switch options. If i remove the line of code that changes Limit switch options, then there is no Axis Disabled fault. This line of code is supposed to re-enable limit switch as i understand it.
Ive also noticed that limit switches are not stopping any movement when i jog machine into them.
Any ideas?
Troy
--- In DynoMotion@yahoogroups.com, "tmday7" wrote:
> Hi Tom,
> Pulse Estop
> Troy
Group: DynoMotion Message: 7476 From: tmday7 Date: 5/16/2013
Also added a xls sheet of pin and bit designation named PMDXpinsToKFLOPpins.xls
Troy
> to this...
> Any ideas?
> Thanks,
> Troy
> > Hi Tom,
> > Pulse Estop
> > Troy
Group: DynoMotion Message: 7477 From: tmday7 Date: 5/16/2013
I believe we got it.
When i changed the pin and IO bit for limit switches i also needed to change the bit to watch in the Limit Switch Options. After i changed the Limit Switch Options Z axis would work correctly but X and Y limit switch would not stop when jogging axis into it. Until i went back into my init C program Mach3_CL_PMDX-125(Version5,1).c and changed the line....
if (*pin == 1)
back to...
if (*pin == 0)
Now all appears to be working correctly. :)
Iam sure ill need more help, as i will be adding physical CycleStart,FeedHold and Stop buttons. And 4th axis A.
Troy
> Troy
> > to this...
> > Any ideas?
> > Thanks,
> > Troy
> > > Hi Tom,
> > > Pulse Estop
> > > Troy
